Opinions On The Following Cams
Old 12-13-2007, 10:39 PM
1999ssls1's Avatar
Default Opinions On The Following Cams
Im doing another cam swap and was wondering which cam would make more power and pull harder. PTV clearance is not an issue. This is going in a forged 347 with diamond flat tops and TEA 5.3 heads.
Cams are....
1. Ms3 603 609 237 242 on a 112
2. Comp Cams 608 612 240 244 on a 112
Thanks
Old 12-13-2007, 10:45 PM
rocksws6's Avatar
I would take the 2nd one. If your going to go big why not go with the biggest.
Old 12-13-2007, 11:02 PM
1999ssls1's Avatar
Thats the cam thats in it now. I was thinking about the ms3 though....
Old 12-13-2007, 11:10 PM
rocksws6's Avatar
I don't understand why you would want to do that unless the 240/244 is to big for you. Your not going to make any more power by going to the MS3.
Old 12-13-2007, 11:16 PM
1999ssls1's Avatar
The car pulls like a freight train. But everyone tells me I will benefit more from a smaller cam with my heads.
Old 12-13-2007, 11:20 PM
rocksws6's Avatar
Well if that's the case I'm just going to be quite because I don't see how that's possible. Unless they're talking about power under that curve. That would make sense. Talk to Patrick he could probably steer you in the right direction. Best of luck.
Old 12-13-2007, 11:22 PM
1999ssls1's Avatar
Well Im always a fan of the bigger cam. I just dont want to do a cam swap and not benefit from it. You know?
Old 12-13-2007, 11:36 PM
rocksws6's Avatar
Oh yeah I hear yah, but cams are all about compromise so give a little to get a little. I personally wouldn't want to run a cam that big in a street car. I would want to stay around the 230 to 236 range. But its all about what you want. But if I was going to chose between the 2 you posted I would take the one you got.
Old 12-14-2007, 08:13 AM
1999ssls1's Avatar
Thanks. I think im gonna keep it. I also have a 244 244 on a 114 I can put in.
Old 12-15-2007, 12:50 PM
PREDATOR-Z's Avatar
They both are in the same range, in the same combo, graphs might almost overlay. What is your air intake setup like? MAF/TB/Intake?
Old 12-15-2007, 01:49 PM
JPH
JPH's Avatar
I would put the smaller cam in it myself.
