valvespring question
Old 12-14-2007, 07:42 AM
lightemupls1's Avatar
Default valvespring question
plan on doing a tr224 112 lsa cam swap. how much lift will the stock ls1 springs take? and what about rockers and pushrods? will they be ok for this cam?
Old 12-14-2007, 08:16 AM
sroach20's Avatar
you need to change the springs and pushrods, rockers will be fine. you can get some comp 918s for cheap or the patriot dual springs for around $240, they come with springs, retainers, and locks. the duals are a good security blanket, if one spring snaps you will have another to keep a valve from playing pinball in your cylinder. then you can pick any kind of hardened pushrods.
Old 12-14-2007, 08:31 AM
SOM 02's Avatar
if u want 918 springs i have some. springs are used. but has new seats,locks,retainers. posabaly something else. if your intrested let me know. whats a fair price for these springs. the springs are in good shape patriot reinstalled them on my heads. i needed stronger springs so have no use for these. just let me know. thanks
Old 12-14-2007, 09:30 AM
TA1364's Avatar
Id go with duels no doubt for added security, especially if you drive the car a lot.
Old 12-14-2007, 09:46 AM
massls1guy's Avatar
I went with new PAC 1218's from SDPC (sdparts.com). I would avoid used 918's if I was you given their track record.
Old 12-14-2007, 10:36 AM
gmpp makes a hot cam that comes with ls6 springs and they say you can run the stock pushrods for $415. the duration is 218/227, why is the intake so much less than the exhaust? and what would be the advantage of the tr224/224 over 218/227?
Old 12-14-2007, 10:48 AM
Ericbigmac83's Avatar
Ive got some pac 918's if you want them, got like 1000 miles on them. good to .600 lift
Old 12-14-2007, 11:18 AM
1970judge's Avatar
The springs need to be changed as well as our pushrods to a hardened. Rocker arms will be fine. 918's/928's will be fine for that particular cam.
Old 12-14-2007, 11:38 AM
memcgraw's Avatar
I'm thinking similar cam, just maybe the TR224 114, and I'm a newbie when it comes to LS1 mods....do you recommend going with 5/16" or 3/8" rods? Do you need to stay with 5/16" if stock rockers are retained. The Patriot dual springs look good. Would a change to the Patriot PN 2009 LS1 Stage II heads make sense to do?
Old 12-14-2007, 11:43 AM
1970judge's Avatar
A nice set of heads to accomodate the cam is always recommended. Heads that flow more than stock are never a bad idea per say but always get a set of heads that match the cam. Pretty parts are nice but only when they work together.
