62cc AFR 225 finally available (and in stock)
Guys,
I should have made this announcement a month ago but better late than never.
The 62 cc small chamber (large bore) 225's have been available now for quite some time.
I have a spent alot of time redesigning the chamber configuration and valvejob height to leave you guys with a small chamber 225 (guys looking for higher compression) without any adverse effect on flow. As an added bonus, intake manifolds and accessory bracket holes are all in their standard position at 62 cc's versus a larger milled head which would effect manifold height (and location) as well as accessory holes on the endpads.
The AFR P/N for these heads are 1610 and their pricing is the same as our 72cc 225's...
Also, they will require the same head gasket bore as the larger heads....a 4.125 bore (or larger) will be what is needed. The actual chamber width is 4.100. This head can be used effectively on a 3.900 bore engine but it is imperative that you run the larger bore gasket with that combination. The fact the chamber is larger than the bore does NOT pose a problem if you use the proper head gasket as descibed above.
Thanks,
Tony
Thanks,
Tony
LS1 Tech Administrator
Great news Tony. Any chance of getting flow numbers on a 3.900" bore and a 4.00" bore?
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
As long as the new gasket has the same thickness as the old gasket, the larger diameter bore of the 4.100 gasket will have very little affect on compression.
__________________
