Stripped a rocker arm bolt... will helicoil hold?
Old 02-03-2003, 04:47 PM
98NBMSS's Avatar
Default Stripped a rocker arm bolt... will helicoil hold?
I stripped out my head/rocker bolt after doing a valve springs swap. Will a helicoil hold or do I need to replace the head? Please help me. My car is a 98 with boltons and a B1 cam.
Luke
Old 02-03-2003, 04:49 PM
LS1derfull's Avatar
Default Re: Stripped a rocker arm bolt... will helicoil hold?
Helicoil is fine, if installed correctly will hold better than oem threads.
Old 02-03-2003, 05:56 PM
I can shift faster than you.
Jason99T/A's Avatar
I believe the rocker threads come from GM helicoiled already.
Old 02-03-2003, 06:24 PM
LS1derfull's Avatar
Jason, stock threads are alumuinum, they like whole head are t-56 heat treated, but not quite as good as stainless helicoil thread inserts.
Old 02-03-2003, 07:57 PM
SixPak's Avatar
10-4 on the helicoils. years ago I worked in a VW shop, and every air-cooled engine we overhauled got helicoils inserted for the cylinder studs. they worked fantastic, and I can't recall ever seeing one come back loose.
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Quick Reply: Stripped a rocker arm bolt... will helicoil hold?
