MS3 with turbo
Old 12-18-2007, 11:18 PM
Function>Form's Avatar
Default MS3 with turbo
i know it is not optimum but with the right tune will it still be alright?
it wont result in a decrease in power will it,
i want to do a rear mount system on my gto with a ms3
Old 12-18-2007, 11:22 PM
98REDZ's Avatar
if you've got the money and the effort of going to a turbo setup,...why not do it right? Get a turbo cam,....I have a MS3 cam,...and its said by lots to be made for stock cube and designed for stock head 346 cars. In my case i've ran 11's with just the MS3 cam only,.... doubt its designed for a turbo application.
Old 12-18-2007, 11:35 PM
5.3LJimmy's Avatar
The high overlap/early EVO of the MS3 will bleed off alot of the boost. It would be pretty pointless to install a turbo or supercharger w/ that cam.
Old 12-18-2007, 11:36 PM
Now you have my attention
GTOSE's Avatar
Too much lope = tremendous loss of boost.
Old 12-19-2007, 06:11 AM
ok i was just going on the limb that with such an aggressive ramp rate an what not and the turbo being rear mount, that it would do nothing but spool that m*ther f*ucker really fast. LOL
Old 12-19-2007, 07:00 AM
ls1leadfoot's Avatar
i am using my ms3 for my sts set up and l;t's......i'm going to wrap from the collector all the way to the over axle bend......
there is also a guy running a ms4.........yes it is a front mount and they are a lot different......but on the sts site there are tons of applications in the video section that have cams in the 581-601 lift area on a 112-114.......i would do it....
Old 12-19-2007, 09:20 AM
Boosted 99 TA's Avatar
Get a turbo grind...
Old 12-19-2007, 09:52 AM
rocksws6's Avatar
+1 There's no sense in running a N/A cam with lots of overlap on a Tubo car. I wouldn't want to half *** a turbo build to save a couple hundred bucks. Do it right and get a cam with no overlap. Trade somebody that wants to go bigger on there cam. If it were a difference of 1k or more I could see it being a dilema. With what it would cost you to do it right, its a no brainer.
Old 12-19-2007, 10:36 AM
im goin to be doing a custom rear t70 non intercooled with meth probably
Old 12-19-2007, 10:53 AM
Tainted's Avatar
I suggest you have Patrick G or PREDATOR spec you out a cam. They have cams designated for turbo cars for a reason
Old 12-19-2007, 10:59 AM
Jordan S.'s Avatar
A rear mount with a MS3... Thats one hell of a combo right there!
Old 12-19-2007, 12:39 PM
3rdgentug's Avatar
why go through all the trouble of the turbo and cheap out on a simple cam swap, ms3's are popular. you could sell it quick!
Old 12-19-2007, 12:59 PM
Platinum WS6's Avatar
um.....say no to drugs...lol! no a cam with that much overlap would loose boost like crazy!
Old 12-19-2007, 04:08 PM
DarkJuggalo's Avatar
id do it right and get a turbo cam ;D
Old 12-20-2007, 09:25 AM
z-ya's Avatar
Stock ls6 cams work good in turbo apps and are inexpensive.
Quick Reply: MS3 with turbo
