which set of heads?
which set of heads?
I have been doing a lot of research and have narrowed it down to AFR 205s or ET 215s. I also plan on getting a cam somewhere in the 224-230 range. This car is more of a hobby than DD so which would give me the most bang for the buck?
What is working for you guys?
i've been doing more searching and came across patriot heads, they look much cheaper than both AFR and ETP's (ported LS6 style heads) Is there really a significant difference between the overall performance of these three heads, i see similar flow numbers
Check out the TEA ported TFS heads. They have great low and mid #'s and are still strong on top and in the same $$ ballpark as AFR's. After much thought I believe that is what I'm going with but I need to figure out a cam to complement them. The 13 degree valve angle offers several advantages including more PTV clearance without flycutting if you want to run a big cam. Just a thought!
I am going with the AFR's myself and currently have them on order at AFR.
As for your question on the Patriot's, which head are you referring to? They have a line of ported heads based on GM casting and recently introduced their own casting, although I am not sure of its availability at this point.
