how much will a complete overhaul cost??
i wanna overhaul my engine cause its a 98 and its not as strong as it should be where can i buy a full rebuild kit and how much head gasket set pistons everything?? p.s. i just put in a cam but i think it needs a rebuild i put in a new oil pump ls2 timing set valvesprings pushrods i want a rebuild kit!!
whats the milage look like? there are cars on here with over 150K on the clock still getting well over 300rwhp stock. If it's not tuned with a cam it can run like poo. try doing a complete tune up too.
it has 93k... but my dad told me when we were buying it that the guy had cut the wires from the odometer, cause when we test drove it the mileage wouldnt show we got back and my dad mentioned it and the guy said it was a fuse, he replaced the fuse right in front of me and it read 71k but we didnt drive it again till i actually bought it a week later so i dont know if thats the real mileage it could have 200k who knows
To find the health status on your motor you should do 2 things:
1- Compression test
2- A leakdown test.
The result of these 2 will give you a pretty good idea where you stand.
I would tune it anyways, because after the rebuilt (if you do one) the tune will still be good and can be adjusted for free or just some dyno time.
always tune your motor, you could be ruining it as we speak.
1- Compression test
2- A leakdown test.
you are going to have to have the car tuned NO MATTER WHAT
LOLOLOLOL you cant just install heads, cam, or other big mods and expect the stock pcm to provide adequate fuel... can you?
dont be a cheap ***, get things done right.
when I had mine done i used all stock parts:
crank
pistons
bolts
gaskets
lifters
oil pump
LS6 oil pan
bearings
rings
machine work:
milled heads
valve job
cross hatched bores
line hone block
$2,688
I got screwed by a family friend on the rebuild though should have been around $1,800
crank
pistons
bolts
gaskets
lifters
oil pump
LS6 oil pan
bearings
rings
machine work:
milled heads
valve job
cross hatched bores
line hone block
$2,688
Take Predator's advice and do some simple tests - also do all the routine maintenance you can think of....plugs, wires, fuel filter, run a can of top end cleaner through the engine (search for info on that one). Throwing money at the problem is not always the best thing to do.
if it really was the fuse the computer would still log the miles
This is what i snapped some pics of so yall tell me what you think of these pics i took a vid but i cant seem to get uploaded to the laptop im really frustrated with this ****** car!!!!
