F11-Futral Flycut Question
Old 12-26-2007, 11:15 AM
tee-boy's Avatar
Default F11-Futral Flycut Question
Anyone know if would have to flycut on stock heads or AFR 205's for Futral F11?
Old 12-26-2007, 11:36 AM
jzzamesb's Avatar
You'll be fine on those heads with that cam.. You only need to worry about flycutting (in regards to this cam) when you start milling them down quite a bit!
Old 12-26-2007, 11:44 AM
PREDATOR-Z's Avatar
not an issue on cam only applications, as for AFR205s you could mill .020 safely
