UD Pully w/ Heads Cam swap
Hey guys,
Getting ready to do my PRC 5.3 & TR224 install next weekend and just wanted to make sure I covered all of my bases. My question is should I go with an underdrive pulley? What kind of gains will I see with the head/cam setup. I've done a search and it seems like everyone talks about doing it to near stock cars. Just curious if I should spend the money on something like this.
Thanks for your help
I put one on with that exact head cam combo and put down 402rwhp through an auto. There is no reason not to because you will likely raise the idle when you get the tune anyway so you wont have to worry about charging problems. If you havent already you should get a .04 thick head gasket to raise the compression a little.
