good deal?
good deal?
i would like to hear what you guys think. I am looking at a engine here are the specs
409 sbc shortblock pro built by rce
4 Bolt 400 with ARP studs
SCAT 4340 crank
SCAT 4340 H-beam rods with bolt upgrade
Diamond forged dome pistons
Cloyes Hex-a-just timing set
Canton pan
ATI Super damper
SFI flexplate
Custom comp solid roller cam
Comp roller lifters
ARP tapered head studs
13.5/1 compression on 64cc heads
he's asking 2650 im not familiar with this block but is it a good deal or underpriced and something wrong. its been raced and made 600/575llbs trq.
SCAT 4340 crank
Canton pan
ATI Super damper
SFI flexplate
Comp roller lifters
What is the casting number on the side of the block? Is it a 509 or 511 block? One of the more important questions, what heads are on the engine? Is it in a car where you start and hear it and check oil pressure while it hot?
