head swap, bolt hole and coolant question
Someone suggested to me to tap the bolt hole to get the crud out...sound good? will it work?
Just use air compressor, Meanards has a cheap air blower 5$ that is about 12 inches long,bend it to fit all the way down to bottom of bolt holes.Dont forget to clean out bolt holes with an old bolt . Cut 2 grooves the lenght of bolt in the threads for the crap to accumulate, and run it in and out several times, then blow out with air.
A tap isn't going to get the coolant out. I used a straw and my air compressor to blow them out. You need to be 100% positive you get all of it out or you will crack the block when you put it back together.
worse case is if I can't find it, I'll do the bolt deal
but in case I can get one, I wanted to know if it would work well...I think some confusion in the thread came in when I put coolant, meant to put dirt and particles.
95% of the time the holes are not contaminated. Just inspect each bolt when removing them. Then I just blast them with my air gun to make sure the holes are dry. If not the bolts will not seat correctly. Are you using head bolts or studs? I perfer studs.
