few questions about cam swap and adjustable rr's...
ok, im doing my MS4 swap, wondering what gears to go with. ive been planning on 410s but just wondered if i should go lower than that. not DD, dont care about mpg, just want as much performance as possible but still good driveability. also i ordered HS 1.7 adjustable roller rockers, how much adjustment do these give? i know i obviously still need the right length pushrods, but just curious as to how close they need to be...thanks for any replies!!
also, im doing cam, stock heads milled w .040 gasket for 11.5:1 CR, rr's, tb spacer, clutch, rod bolts, 160* t-stat, ported tb, flycutting, e-cutout, dyno tune...i already have full bolt-ons minus EWP, and car is an 02 ss M6. my goal is to hit 425+ rwhp. think i'll get it???
Do they come with the pushrods? If not, there is a way to determine the correct pushrod length/adjustment. I worked mine out with the Cranes on the workbench by obtaining the best wipe and then measuring the adjustment nut position such that when I put them on the car I knew where to set the rocker to measure for the pushrod.
Where is the adjustment nut on the YT's, it is at the stud or at the pushrod?
