stock 243's worth it???
Old 01-10-2008, 11:06 PM
BarneyMobile's Avatar
Default stock 243's worth it???
I recently had the MTI stealth 2 cam installed(224/220 .581/.581 116lsa). During the install, we found that 2 lifter where not pumping enough oil up to the rockers and it wor down the end of the push rod and rocker. Now this means I have to pull the heads to replace the lifters . If I'm pullin the heads off, it would seem pointless to put stock 853's back on the car. I can get stock 243's to put back on the car. Now my question is, are stock casting 243's worth putting on. Right now I'm on a tight budget. Im not sure if I can save up for ported heads right now. How much more power would they make over my stock 853's with my new cam? I dont have any dyno # right now to go off of.
Old 01-11-2008, 12:11 AM
Evans752's Avatar
Yes they are worth putting on because thats all I have stock 243 with the valve spring change only(Comp Cams 921), you will gain 15 to 20rwhp and around 2/10 in 1/4 mile is what I have seen out of the cars Ive done. Good Luck
Old 01-11-2008, 06:14 AM
Shawn @ VA Speed's Avatar
agreed,stock 234's are a great head,def a good swap
Old 01-11-2008, 09:11 AM
rickyracer25's Avatar
Yes!!!!! Do It!!!
Old 01-11-2008, 10:17 AM
buddha845's Avatar
hell yea, the 853's seem like a pretty big restriction compared to the others. i went from 853's to 241's on a stock ls1 and i noticed quite a big difference. 243's would be a nice upgrade, especially on a budget
Old 01-11-2008, 03:10 PM
or would it be worth saving up for a set of ported stage 1.5 5.3l heads? livernois has a set for about $950.
Old 01-11-2008, 03:42 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
You can get a set of 243 castings from Patriot for about $400. They are definetly worth it.
Old 01-11-2008, 04:28 PM
Medic/Z28's Avatar
Thats true. I got mine for $450 assembled except for the springs, push rods, and lifters. I used new yellow LS6 springs, harden 7.4 push rods and new LS7 lifters.
