Introducing K1 Technologies/Wiseco Rotating Assemblies! WRE 40th Anniversary Specials
Old 01-11-2008, 08:58 AM
WeberRacingEquipment's Avatar
Default Introducing K1 Technologies/Wiseco Rotating Assemblies! WRE 40th Anniversary Specials
Weber Racing Equipment is celebrating 40 Years of building racing engines and selling performance parts in 2008!
We are introducing our Stage 1 and Stage 2 lines of engines and offering some huge discounts! We are going to have some sleeved engine packages released as well as long block options released very soon. If there is something you have in mind and do not see listed please contact us and let us know what we can do for you. For a listing of our short block options Check out the link here:
http://weberracing.net/Engine-Type-G..._31/index.html
We are also proud to announce K1 Technologies balanced rotating assemblies! These rotating assemblies come with K1 Tech 4340 Forged Crankshaft, K1 Tech Steel H Beam Rods w/ ARP 2000 Rod Bolts, and your choice of Wiseco Piston to meet your needs! Custom pistons and piston coating are upgradeable options! These rotating assemblies are on sale for $2075!!!
Click here to put your package together:
http://weberracing.net/Engine-Type-G...184/index.html
We are also offering specials on rebuilding your current engines and all internal engine parts! PM, call or email with your inquiries!
Old 01-11-2008, 09:04 AM
THEBRAD's Avatar
thats cheap as ****! whats hp rated at? for the rotating assembly
Old 01-11-2008, 09:08 AM
rickyracer25's Avatar
pm sent!!!!!!
Old 01-11-2008, 09:24 AM
It is hard to put a horsepower rating on something when so many other things come into factor. We have used these components in builds in the 1000 RWHP range without an issue. Of course tuning, machining, and assembly all play vital role in and engines performance.
Old 01-11-2008, 09:25 AM
THEBRAD's Avatar
awesome man thanks i just want about 600 na so that should do the trick. they will handle 7500rpms then also im guessing?
Old 01-11-2008, 09:30 AM
As long as everything else is right that will not be a problem. Let me know what you are looking to build and I am sure I can help with getting that rotating assembly properly mated into a block for ya!
Old 01-11-2008, 09:36 AM
THEBRAD's Avatar
after i rip her out i'll make sure ur the first i get ahold of, free advice is awesome! lol but seriously good advice from a sponsor selling a great product for such a great price, thats what makes this the best lsx page, sposors willing to help
Old 01-11-2008, 09:40 AM
Anything we can do, let me know
If there is anything we can do, let me know!!
Old 01-11-2008, 09:51 AM
THEBRAD's Avatar
will do, thanks in advance
Old 01-11-2008, 10:10 AM
405HP_Z06's Avatar
Can I get the following information for the 4.00" stroke, 4.00" bore, -8cc piston kit?
1. What is the compression height on the piston
2. What is the piston top O.D.?
3. What is the measurement from the piston crown to the top of the first ring?
4. Who's coatings are used for the optional skirt and crown coatings?
5. Are the wrist pins straight or taper wall?
Thanks in advance.
Old 01-11-2008, 10:27 AM
Thanks in advance.
1. 1.115
2. The piston top O.D. is .054 smaller than the bore at the very top of the top land.
3. .260 with .165 second. Second land is not sacrificed for the top.
4. We use a local coating company that does excellent work for us.
5. Straight are standard, taper walls can be added on.
If I missed anything, please let me know.
-Leo
Old 01-11-2008, 11:12 AM
405HP_Z06's Avatar
Originally Posted by WeberRacingEquipment
1. 1.115
2. The piston top O.D. is .054 than the bore at the very top of the top land.
-Leo
Thanks for the quick response Leo. So for the piston top O.D., it would be 3.946" or .054 smaller than bore diameter?
Also, are the pistons 2618 or 4032? What's the recommended piston-to-wall clearance for a naturally aspirated application?
Old 01-11-2008, 11:14 AM
Correct
lol I just noticed my typo! On there, Ill fix that.
Old 01-11-2008, 11:26 AM
allthrotle's Avatar
It says in the title wiesco rotating assembly's so would this mean we could buy this from a wiesco dealer?
Old 01-11-2008, 11:37 AM
It is actually a K1 Tech Rotating Assembly using Wiseco pistons. Why do you ask?
Old 01-11-2008, 11:41 AM
allthrotle's Avatar
I was just curious. When I saw weisco rotating assembly in the title, I thought that weisco was getting into the rotating assembly game.
Old 01-11-2008, 11:44 AM
405HP_Z06's Avatar
Correct
Thanks, last questions:
Old 01-11-2008, 11:54 AM
Phoenix 5.7's Avatar
what piston and ring choice would you recommend for a 403 thats goin to have a 200 shot of nitrous? and what piston valve reliefs are available for L92 heads?
The pistons are made of 2618
We generally run .004 piston to wall clearance.
Quick Reply: Introducing K1 Technologies/Wiseco Rotating Assemblies! WRE 40th Anniversary Specials
