Who would you call to touch up some cylinder heads...
Old 07-03-2003, 04:28 PM
7 Second Club
Phil99vette's Avatar
Default Who would you call to touch up some cylinder heads...
I am thinking about getting my cylinder heads touched up while the clutch is out. Who would you send them to?
Phillip
Old 07-03-2003, 04:32 PM
I can shift faster than you.
Jason99T/A's Avatar
Default Re: Who would you call to touch up some cylinder heads...
GTP is all I have used and couldn't be any happier!
Old 07-03-2003, 04:44 PM
Smoke_Ford's Avatar
I have my machining guy here in IL, I'd be more than happy to give you contact info if you PM me.
Old 07-03-2003, 05:09 PM
Vents's Avatar
depends on the money you want to spend. GTP will get you the top of the line cyllinder heads w/ a flow sheet. if you just need a "cleanup" job as in a valvejob, guides, seals, new valves, and some minor port work, you can either take the time and learn it yourself, or look for somone that is comfortable making these kinds of changes w/ the help of a good machine shop.
Old 07-03-2003, 06:57 PM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
One of the things I will say about GTP is that they have played around with their vavle jobs to find which agles make better flow. If anyone doesn't believe that matters, look at a GTP flowsheet. One of the secrets is the valve job. A god valave job can mean 20cfm. Whoever you decide to go with make sure they can do some nice seats instead of some production shop" crummy job with wide angles and poor flow.
Old 07-03-2003, 07:22 PM
JPR
JPR's Avatar
We have touched up a variety of heads out there including Fireballs with excellent results.
Joe.
Old 07-04-2003, 04:09 AM
C_Williams's Avatar
Send them to Richard at West Coast Cylinder Heads... West Coast Cylinder Heads
Old 07-04-2003, 07:19 AM
Fireball's Avatar
Joe.
Agreed... Joe just did a valve change on my GTPs with his special spec valves and we picked up an average of 4 cfm across the board
Old 07-04-2003, 10:58 AM
SLowETz's Avatar
Give Brian/ Brent a call @ TEA Their stuff is making crazy #'s.......
Old 07-04-2003, 11:43 AM
Smoke_Ford's Avatar
TEA is good, but it may be too expensive for what you are looking for
Old 07-14-2003, 12:49 AM
Phate's Avatar
I agree
Old 07-14-2003, 01:03 AM
Bowtieman4life's Avatar
FOr the money, nothing beats a Patriot head. They flow as good as TEA heads for a lot less. they cost $1295 from Texas Speed and Performance and they don't require a core. HEck, they will even buy your old heads for $200. TEA's ar $1700 + the core. If you got the dough go with GTP or ARE heads. They are the best. They use smaller cylinder ports and flow more at a higher speed which helps with throttle reponse and torque.
Old 07-14-2003, 07:31 AM
Super Moderator
Reckless's Avatar
Since you are east coast, I would send them to Jay at Absolute Speed. No one has proven better thus far.
