Having a hp debate. I say his dyno is generous
Before I give you the actual numbers on the dyno, let me tell you the mods and you guys tell me how much power it should be putting out to the ground. I know every car, dyno, and tuner is different but give me a ballpark.
02+ LS6
stock heads
Magic Stick v3 "MS3" Cam, Kooks 1-7/8" Long Tube Headers, High Flows, Basanni x-pipe, Borla "stinger" quad tip Cat back, Smoothed out upper intake manifold, polished and knifed throttle body, dyno-tuned.
02+ LS6
stock heads
ok this guys claims 472 at the wheels. I told him either
1-he's being lied to
2-he's uninformed
3-his tuner's dyno is extremely generous
i don't know if he's regeared to 4:10 or not. would that make a difference in the numbers?
I also told him there are absolutely no LS6 with just cam and headers with 472 horses. Is this accurate or not?
2-he's uninformed
2-he's uninformed
2-he's uninformed
Oh sorry, I lied there is way one this is possible on stock heads and cam/headers only. Add a 50 shot ontop and there you have your 472. Or I guess unless for some stupid reason that they converteed it to fwhp than yes that would make sense. Never to the wheels though!
allngn_c5 made something like 49x with pretty much every bolt on, G5x3, AFR 205's, Fast 90/90 in his c5. But like I said he has WAYY more stuff done to his 346 than they guy you guys are talking about.
Could be a typo? 427rwhp sounds right on for that setup.
472 with stock heads? Flywheel = Y | Rear Wheel = N
This is one way to make 475rwhp
Why don't you just have him take it to the track? Dyno's are a tuning tool and a tuning tool only, every dyno is different and depending on the calibration will read out different numbers.
The track tells all, dyno numbers don't mean ****.
thats how I feal about it too
