69 Camaro - LS6 cam advice please
I've read and searched here quite a bit and unless I've completely missed the answer to my question I haven't found it yet.
My Cam selection is a bit unusual for this forum. I have a 69 Camaro that I'm doing the LSX conversion on. It will have:
A 2002 LS1 with the LS6 block and the LS6 intake. I don't have to run a Catalytic convertor (smog exempt ) so it'll just have Stainless works long tube headers into a 3" dual X pipe exhaust. It has the M6 T-56 Transmission. It has a 3:73 rear end ratio with 315/35R17 tires. I have a set of 243 casting LS6 heads that I plan on putting on it.
So the question is--- What's a good cam for something like this application. I've thought about just running the LS6 cam but from reading here it seems that the are better options out there. I guess my goals for the cam would be heathly idle, good power, driveability (without comprimising power), and quality. I'd prefer to stay away from Comp Cams as I have several Big Block Chevys and that particular company has a very bad history in those engines.
I appreciate any and all suggestions, Thanks Lance
First off comp cams is the grind on most of the aftermarket cams for a LSx motor. They seem to have the best ramps for our particular engine. I would run a Texas Speed 228R with a 112 lsa, or a 230/232 cam like a Futal f-13 if I were you. Also I would change your rear end ratio to at least a 4.10 to get the most out of the cam. 3.73's with a 6 speed is pretty much worthless unless you are running some serious horsepower.
"Also I would change your rear end ratio to at least a 4.10 to get the most out of the cam. 3.73's with a 6 speed is pretty much worthless unless you are running some serious horsepower."
Wow, Have ever drove or ridden in a t-56 car w/ 4.11???
I totally agree with your cam choices though I'm looking at those 2 cams as well but with 3.55 or 3.73 posi & a 3400 stall with my A4.
OK I've been researching all morning and come up with a couple of options.
There's the Futral F-13 in either 112 or 114 lsa
There's the new Futral F-13 highlift in either 112 or 114 lsa
Then there is a custom cam that Shawn from VA Speed sent me that is 228-232 duration and 598-600 lift
Can anybody give me some feedback on these cams please.
Is anybody here running the new F-13-highlift? I couldn't seem to find much on the newer highlift versions.
Thank you, Lance
Thank you, Lance
i have the ls6 cam and wish i'd gone slightly bigger. 550 lift 204/218 dur on 117lsa. 600 rpm idle , sounds like stock. low dyno numbers. i have an A4 and was worried about idle. since you have a stick you can get away with a bigger cam. just my 2 cents. in your position i'd go with at least a tr224.
Thank you, Lance
Thank you, Lance
I am running a 230/232 604/604 113+1 lsa. Perfect cam for a street/strip car. Like I said you wont be disapointed in the F-13 or the F-13 high lift. almost the same I am running.
??? Do you go more than 10 feet without shifting into 2nd ??? Do you shift at 7200 ??? I would like to take a ride in your car though. With your mods I'm sure it screams!
Heck, for my current build I can't decide between what cam (TSP228/T.2/F12/F13...), what stall (3200-3600) & what rear (3.55 or 3.73) for my A4 LS1....
