Spun a bearing
Old 01-15-2008, 01:34 PM
jpeach's Avatar
Default Spun a bearing
Ok, I spun a bearing. What can I do to my stock LS1 to get it back on the road for $1-2K?
Or
For a little less than $1K I can get a complete 6.0L truck block w/ 60K on it from a salvage yard.
What should I do?
Thanx
Old 01-15-2008, 02:44 PM
99mongooSS's Avatar
forged pistons, forged h-beam rods, factory crank. With machining if you do it yourself the shortblock will cost less than 2k. Slap a cam in in and be done with it for a little bit.
Old 01-15-2008, 02:52 PM
BLACK2001SS's Avatar
well its hard to say man with what it will take to put the 6.0 in your truck might be over 2 grand. If you can pull the motor yourself and all you have to do is replace the berrings and get the crank redone I'd go that way.
NOt an easy decision for me I have way too much money in my ls1 to throw it away I'd fix it and probly build it up more.
Old 01-15-2008, 03:01 PM
99mongooSS's Avatar
i have only spent $1600 on my parts so far for my shortblock ls1 build but I also spent money on a bunch of studs and stuff for the heads and mains. If you use factory style bolts you can put forged pistons in it now for really cheap and if your going to rebuild now would be the time to do that.
Old 01-15-2008, 06:45 PM
Black FormulaLs1's Avatar
throw another $800 at it and get a tsp shortblock and keep your leftovers for parts or sell it outright...or you can buy a used shortblock/longblock and get it freshened up...
Old 01-16-2008, 04:42 AM
SSMOKIN_Y2KSS's Avatar
build yourself a new motor...you should be able to do it for 2k if you have the right hookups
Old 01-16-2008, 06:09 AM
jpeach's Avatar
This sounds like the way to go. Whats a good "starter" set of pistons/rods/bearings?
As far as the cam goes; how much lift can you use w/o a converter?
What should I expect to pay for machining?
Thanx
Old 01-16-2008, 08:30 AM
Thanx
You could basicly pick any cam you wanted it just will have some serging issues haha but not like it would be out of controll. But you will want to get one sooner than later along with a shift kit and trans cooler to help the slush box out.
Old 01-16-2008, 10:00 AM
hokie00 TA's Avatar
im in the same perdiciment and im going the 6.0 way you can pic up a lq4 for less than 1500 bucks and all you stuff from you ls1 will interchange and when you get it back together and you got a bigger cubic in motor.
Old 01-16-2008, 11:05 AM
SSdreamz's Avatar
but if you keep the LQ4 internals the same, youll have a lower compression motor
Old 01-16-2008, 12:41 PM
hokie00 TA's Avatar
change the heads to a smaller cumbustion chamber and it will up the compression.
