Replaced Rod Bearings, How long...
Old 07-05-2003, 10:29 PM
00 Firehawk's Avatar
Default Replaced Rod Bearings, How long...
Should I break them in?
Old 07-06-2003, 12:50 PM
2xLS1's Avatar
Default Re: Replaced Rod Bearings, How long...
With proper clearances and oil pressure, there should never be any metal to metal contact on bearing surfaces. There should always be a film of oil between the bearings and crank. So there should be no break in time on bearings only.
Old 07-06-2003, 12:54 PM
Smoke_Ford's Avatar
How about if you do rods and pistons too?
Old 07-06-2003, 04:34 PM
Using some of my knowledge from my Ford days, I was thinking about 1500 miles to establish a wear pattern. But, I have heard others say that 250-500 miles is sufficient. Any ideas on that theory?
So far I definetly like 2xLS1's idea.
Old 07-06-2003, 11:13 PM
TTT
