How did I blow my head gasket?
Old 07-06-2003, 01:09 PM
SSG-Z28's Avatar
Default How did I blow my head gasket?
I just installed different lifters and after I started the car, it started steaming. I immediately parked and found out that the driver's side was steaming like mad.. What are some possible causes? This was my first time trying something like this, so I'm sure there is quite an extensive list...
Old 07-06-2003, 01:11 PM
2xLS1's Avatar
Default Re: How did I blow my head gasket?
Which head gaskets did you use?
Old 07-06-2003, 01:14 PM
SSG-Z28's Avatar
I bought new stockers.
Old 07-06-2003, 01:15 PM
Krazy98Z28's Avatar
You might of not torqued the head down correctly.
Old 07-06-2003, 01:17 PM
SSG-Z28's Avatar
Hmm, that is quite possible..
Old 07-06-2003, 01:21 PM
SSG-Z28's Avatar
Is there a slight possibility that the gasket is still usable?
Old 07-06-2003, 02:43 PM
SNAXS's Avatar
Id buy new ones.
Old 07-06-2003, 04:31 PM
Tim 98z's Avatar
Did you use new bolts, clean the block and heads real well, torq properly then go the correct degree further....????
Old 07-06-2003, 05:08 PM
LS1Tech Sponsor
Slowhawk's Avatar
Did you bleed the air out of the cooling system real good?It takes about a 1/2 hour of slowly pooring in the coolant to get all the air out.It sounds like you had alot of air in the Heads and it overheated the head causing it to blow the gasket on you.
Old 07-07-2003, 01:23 AM
SSG-Z28's Avatar
Thanks guys.. I will do it right next time.
