LS3 heads?
Old 01-18-2008, 05:01 PM
Omega Doom's Avatar
Default LS3 heads?
will they fit a stock block LS1?
Old 01-18-2008, 05:57 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
yes... but the LS1 intake manifold wont fit the heads...
Old 01-18-2008, 05:59 PM
Omega Doom's Avatar
what about the LS6 intake?
Old 01-18-2008, 06:02 PM
ChevyChad's Avatar
nope...
Old 01-18-2008, 06:04 PM
Brad Hutchcraft's Avatar
you would need an L76 intake.
Old 01-18-2008, 06:41 PM
A_VAS's Avatar
I wondered this myself...I saw a set on Ebay recently...asked the guy and he said they were 243 castings, but didn't know the chamber cc or valve sizes.
If they are 243's are they using this casting and changing the intake bolt pattern?
Old 01-18-2008, 06:48 PM
Order 66's Avatar
The LS3 head will fit a LS1 block. But the LS3 is made for a 4.06 bore and the LS1 bore is 3.9. its a little to big.
Old 01-18-2008, 06:54 PM
fenix999's Avatar
exactly, but just because its made for soemthing else doenst mean it wont work, and work well it does. You just need the right intake with the right rockers (exhaust i believe) and if you keep the L76 injectors you have to get an adaptor harness from speartech to you those "newer" style injector with your "older" style LS1 injector harness. The "newer" LS2 and up injectors are shorter and have a different plug as well. Hope this helps
Old 01-18-2008, 07:52 PM
5.3LJimmy's Avatar
They won't work on a 3.9" bore b/c of the 2.16" intake valve. They require a minimum 4" bore.
Old 01-18-2008, 07:53 PM
RGKSR's Avatar
Default Ls3 = L92
I thought the LS3 head was the same casting as the L92 head. If that's the case then they will not fit on a LS1.
Bob K.
Old 01-19-2008, 06:33 AM
LS1W66's Avatar
Bob K.
Yes LS3 and L92's are the same castings so they won't work on an LS1/LS6
