Sponsors/Engine Builders - Need ring gap info
Old 07-07-2003, 07:38 AM
Super Moderator
Reckless's Avatar
Default Sponsors/Engine Builders - Need ring gap info
Gonna be building my new motor soon. What is the best ring gaps to use for NA and occasional N2O use? They are Wiseco thermal coated pistons (4-inch bore) with the usual ls1 hipo rings (forget the brand).
Old 07-07-2003, 08:48 AM
LOnSLO's Avatar
Default Re: Need ring gap info
.024, .024, .015. Top, middle, oil rings.
Old 07-08-2003, 07:47 AM
Super Moderator
Reckless's Avatar
Thanks LO...anyone else have a differing opinion?
Old 07-08-2003, 10:05 AM
LOnSLO's Avatar
Todd, those are obviously just ball park numbers. Little on the loose side on the top 2 rings for nitrous use.
Old 07-08-2003, 07:00 PM
Senior Member
Country Boy's Avatar
From Chris @ Diamond...
gaps at .016" for the top rings and .018" for the 2nd rings. This will be good for naturally aspirated and also light nitrous
Old 07-08-2003, 07:49 PM
Super Moderator
Reckless's Avatar
That is quite different. And what about the oil rings?
Old 07-08-2003, 08:45 PM
Senior Member
Hummm.. didnt know you had to file fit oil rings since they are just scrapers.. Hafta check on that one
Old 07-08-2003, 08:58 PM
1dirtyZ's Avatar
i thought the rule was .04 inch for every inch of bore??
Old 07-09-2003, 09:15 AM
Jimmybob's Avatar
for an LS1 or Ls6 top ring .16 middle ring .12 oil .08
Old 07-09-2003, 02:05 PM
Super Moderator
Reckless's Avatar
So the concensus is that no one can agree on this
Any full-time builders want to chime in? ARE? MTI? FMS?
Old 07-09-2003, 02:21 PM
1999_SS_M6's Avatar
I may as well chime in too.. This is how I would set the engine up for Street use with light NO2.
TOP RING: .006 per inch of bore dia.
MIDDLE RING: .005 per inch of bore dia.
so in your case, .024 on top, .020 in the middle.
Old 07-09-2003, 02:56 PM
98 Silver Bullet's Avatar
OK.....which is it? One person says .16 and another says .016. One person says .04 per inch of bore and another says .004. WTF
Old 07-09-2003, 03:13 PM
Senior Member
Hey Reckless.. I got the email back about the ring gaps from Chris. I asked him if he agreed with what he told me before and here it is:
That ring gap will be fine with up to a 150-200 shot. If you are going above that open them up to .018 top , .020 on the second. The center oil ring does not get filed. The rails that support it need to have .015 minimum and no more than .060
Old 07-09-2003, 03:18 PM
Super Moderator
Reckless's Avatar
I thought the oil scraper was the bottom ring? Last time I did rings, I had to file the top two I believe, and did not alter the oil ring (scraper on bottom). This is getting more and more confusing
1999_SS_M6's Avatar
Well, I will stake reputation and ASSURE you that it isn't .040 per inch of bore. I just think that .004 is too tight for a nitrous motor. That's fine if you want to go NA, but with the extra heat and pressure, if you go too tight on your top ring, you're going to pop your top ring land and grenade the motor.
Look at it this way, if you give it a few extra thousandths on top, you may sacrifice 10-15 PEAK NITROUS horsepower, but wouldn't that be worth it as insurance if you ever overheated the engine?
There are lots of tricks to running nitrous safely.. You can get a piston that puts the ring lands further down from the top, you can increase gap, yada yada.. There is no "RIGHT" way. Just several different preferences that engine builders use. Don't believe me?? Call 4 REPUTABLE engine builders and if you get the same answer from all 4, you can use my lift to do your motor swap!
Old 07-09-2003, 03:28 PM
Senior Member
LOL
You have:
ring land 1 (top) compression ring #1
ring land 2 (second) compression ring #2
ring land 3 (bottom) Oil scraper ring (has top scraper, senter expander, and bottom scraper)
You dont touch the middle one (the funny lookin' up and down one ) You just file the top and bottom scrapers. You can have a big margin of gap because they arent under any pressure, they are just oil scrapers. Hence why most are low tension
Better?
Old 07-09-2003, 03:32 PM
1999_SS_M6's Avatar
Bottom line, I'd call your piston manufacturer and ask them... Then call your Ring manufacturer and ask them.. That's the only way to be safe. I don't want to tell you the wrong info, the only motors I've set up for NO2 from the ground up were SBC Iron motors.
GOOD LUCK!
Old 07-09-2003, 06:44 PM
Super Moderator
Reckless's Avatar
OK guys, I have done this before for my turbo motor, and Nick Agostino didn't make things nearly as complicated as you guys are
So,
Top ring - ???
2nd ring - ???
oil scrapers - ???
You guys are making this way too hard
Old 07-09-2003, 06:48 PM
Senior Member
.016
.018
.015 - .060
Old 07-10-2003, 03:06 PM
Super Moderator
Reckless's Avatar
ttt
Quick Reply: Sponsors/Engine Builders - Need ring gap info
