00 vs 01 engines
Old 01-21-2008, 04:06 PM
Ehop's Avatar
Default 00 vs 01 engines
i will soon be having an LS1 project car. i've heard that 01 are much better engines to start with than earlier years. why is that?
Old 01-21-2008, 04:11 PM
87gnx's Avatar
Just a F.Y.I. try the search.....
Old 01-21-2008, 04:56 PM
Shawn @ VA Speed's Avatar
has better heads and intake,block is a little better than the real early ones,better oiling and thicker sleeves
Old 01-21-2008, 05:58 PM
moeZ28's Avatar
But didnt 2001 have the whole piston ring trouble with oil consumption?? I thought I read that the 2001 model cars had different rings that they had to change in 2002 b/c they werent as good as previous rings.
Old 01-21-2008, 06:01 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
I don't know about the ring issue, but they are different heads, intake, cam, and different exhaust manifolds and cat placement. The head change actually happened mid 2000, some had 241s and some still had 853s
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 01-21-2008, 07:15 PM
WAHUSKER's Avatar
And there is the oil pump failure they also supposedly fixed in 01
