installing timing chain. stock oil pump.
Old 01-21-2008, 04:12 PM
food nd cars's Avatar
Default installing timing chain. stock oil pump.
As the title says im going to be installing my tr224 cam soon and want to replace the chain without taking of the oil pump or at least without taking off the pick up tube.. is it possible? and is the dealership a good place to get the LS2 chain from?
Old 01-21-2008, 04:38 PM
sroach20's Avatar
the chain is behind the pump!
Old 01-21-2008, 04:42 PM
DaveX's Avatar
Yeah you have to remove the pump. The pump is driven by the crank sprocket. It's not that bad of a job, just take your time and have a pen magnet handy just in case you drop the pickup tube bolt. And when you put the pump back on, make sure you tighten it down before you tighten down the pickup tube bolt all the way so you don't pinch the o-ring on the tube. And make sure you get a new o-ring. You can get the LS2 chain at a dealer, I got mine at SDPC.
Old 01-21-2008, 04:50 PM
should i get a new O-ring for the pick up tube or can i most likely reuse the old one?
Old 01-21-2008, 05:20 PM
massls1guy's Avatar
Here's a good guide:
http://www.ls1howto.com/index.php?article=23
I replaced the O ring, why not replace it while you have it apart. I think it was about $5 from the dealer.
I wrapped a long wire around the pick up tube bolt to be sure I didn't lose it.
Old 01-21-2008, 05:35 PM
NHRAFORMULA00's Avatar
you MUST replace the o-ring,or else you will be pulling it apart again.it is not reusable even though it appears OK.
Old 01-21-2008, 06:01 PM
vettenuts's Avatar
O-rings are cheap. Buy two or three, that way if you mess up and pinch it you don't have to order another. Lube it good (I use Redline Assembly Lube) after you put the o-ring on the tube then center the tube while inserting into the pump.
Old 01-21-2008, 11:19 PM
when i hammer in the new front engine seal, should i hammer it in from the front or the back?
Old 01-21-2008, 11:56 PM
massls1guy's Avatar
Check out the link from ls1howto.com that I sent you above. Here is a quote from it:
Now, we need to put the front cover back on; however, it's best to not reuse the front seal that is pressed into the hole in the middle of the cover. Using a big flathead screwdriver and a hammer, hammer the seal out from the back of the cover as shown in the picture. Hammer all around the seal and work it out. This may require some pretty heavy hitting with the hammer.
Once you have removed the seal, place your new seal centered on the hole. Using a block of wood or very careful hammer placement, tap the front seal into the hole. Again, this may take some trial and error as when you hammer one side in, the other will pop up. That is where the block of wood comes in handy as you can hammer the whole seal in equally using it.
Since you hammer it out from the back, you have to hammer it back in from the front. Once you go through the removal process the install should make more sense.
Old 01-22-2008, 01:34 AM
99mongooSS's Avatar
be carefull not to drop the pickup tube.
Old 01-22-2008, 05:27 AM
DaveX's Avatar
I said something backwards above. When installing the pump, start the bolts that mount the pump but do not tighten them yet. Install the pick up tube, and tighten it all the way. Then tighten the bolts that mount the pump. If you tighten the pump first you will likely damage the o-ring and have to take it all back apart.
Old 01-22-2008, 08:45 PM
arite cool.
Old 01-23-2008, 11:43 AM
chrs1313's Avatar
i have an extra ls2 chain brand new in the package if you want it for 35 shipped...let me know...pm me for paypal address...
Old 01-24-2008, 05:55 AM
eallanboggs's Avatar
Be sure you orient the seal properly. If you look at the seal closely you'll see that the lip is canted in one direction. That canted side goes toward the engine. That way when you push the pulley home the lip of the seal will hug the step on the pulley. If you put it in the wrong way the seal lip will be forced backwards(sort of like bending your knee in the wrong direction) and it will eventually fail. Don't beat the seal in with a hammer. Cut a 4"X4" piece out of a 2X6. Place the cover on a large flat table. Place the seal on the cover and slowly hit the piece of wood to drive the seal home.
Old 01-24-2008, 09:21 AM
bowe1632's Avatar
that is nothing like bending a knee in the wrong direction...lol
