Looking for possible SCR and DCR calculations for custom cam
My setup as of now:
TSP 5.3L stage 2.5 heads
MS3 cam 113lsa
stock HG's
Looking at doing a custom cam to help the low/mid range without sacrificing much top end.
Cam is a 233/237 on a 110, lift is around .630/.600.
Thoughts? This should clear without flycutting but im not 100% sure.
Car made 440rwhp 389rwtq with the setup above and LS6 Mani, ported LS6 TB, K&N filter with HF bridge. In addition to the cam I will be adding a Vengeance ported Fast90, ported LS2 TB, UDP, and Vararam, will be hoping to get close to the 470 range and have a lot stronger torque.
Thanks!
MS3 cam 113lsa
stock HG's
Thanks!
My setup as of now:
MS3 cam 113lsa
stock HG's
Thanks!
MS3 cam 113lsa
stock HG's
Thanks!
Cam:
advertised specs
cam manufacturer
lobes
advance or retard ground in cam or Intake center line
Engine:
Stock short block?
LS1?
combustion chamber volume
pistons flycut?
It is a stock short block LS1 and the 5.3L heads are said to be between 62-63cc. The pistons are not flycut currently.
LS1 Tech Administrator
Get ready to flycut. That's a healthy stick and your 5.3L heads have smaller cc chambers and larger valves than stock. This hurts P to V clearance. But go ahead and plan on flycutting because the gains from the ported heads and better intake should give you a HUGE boost in power from where you are now.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
