help cant decide on cam
Old 01-23-2008, 09:10 PM
Dangerous SS's Avatar
Default help cant decide on cam
well i have been trying to decide what cam to install in a 2001 ls1 6speed...it has 410 gears and the reg bolt on with a 90/90 set up with a 125 shoot and stock ls6 heads. the car runs 95% of the time on motor
Old 01-23-2008, 09:58 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
With the gearing you have available you have a great opportunity to run a really healthy camshaft! I'd look to something like the MS4 camshaft. We've seen 450rwhp out of stock ls6 heads & the ms4 camshaft! What kind of power does the car make currently?
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-24-2008, 10:07 AM
the car has a custom cam in it that is around a 224 or so... it made around 410 or so on motor but the cam is like 5 years old so it time to move up to something bigger. this numbers was before the intake...i cant recall what it made on bottle since it been a while
