Trick Flow pushrods... as opposed to Comp Cams
I was talking to Brent from TEA and he told me to save the money on the Comp Cams and just get the Trick Flow pushrods. Does anybody have any experience with these pushrods... and what are your thoughts about them and about the reccomendation?
Re: Trick Flow pushrods... as opposed to Comp Cams
Was running them in my 94Z. Wish they'd failed instead of my double roller CompCams timing chain.
(so yes, they are good and I would / will run them again)
-Andrew
-Andrew
Good feeback guys... is there any real difference between the mustang piece and the one for a LS1?
Is there anybody with them in a LS1 f-body?
Thanks
Thanks
I've ran the TF p-rods on my last two setups (7.40" and 7.35") without a single issue. They are every bit as good if not better than any other p-rod available for our cars...the only difference is that that the T-flow p-rods are less expensive (Summit has the best prices around...about $75-80 if I remember correctly.
I am running them, 7.35 inch. No problems. I sold my CC 7.4 inchers when I changed heads and bought the TF 7.35 inch pushrods.
