Little Hlp Throttle Body
I took my throttle body apart today and when i was pulling out the main shaft a little washer came out ? Where does this go and does anyone have a breakdown of one of these throttle bodys?
OK so i put it back together the way i thought it came apart and know my throttle hangs at 2000 until i come to a stop . I can even push in on the clutch and it still wont come down until I stop what the hell did i do wrong here?
i'm fairly sure that when you took out the iac valve, you may have pushed it in. i've done this before but after a few starts it went back to normal. the washer you dropped goes between the TPS sensor and the bearing.
lol
no still no luck i just went and bought new iac and tps and still does the same thing. ONlY when i come to a stop for about 30 seconds does it stop. I put back together right i stuck that washer on the end where tps is and had to tap it into place all the way down right? seems like everything i touch now days turns to ****. uggggggggggggggggg
That washer is not needed, it goes on the end of the shaft where the TPS senser is. Porters usuallly dont even put them in becuase there isn;t side load on the shaft. Is the throttle sticky like the blade is not centered and isn't closing completely making the IAC take up the difference. If that not that case I would say the hole is your problem. I know Pat G knows his **** so did you follow his directions on the size of the hole. If so I would JB weld it shut, smooth it out, and try a little smaller hole.
