Got a bit of a rod bolt dilemma, need sugesstions
Alright well I just talked to Katech and it's going to be at least the end of February til they can get their rod bolts back in stock again and I'm in the process of doing my H/C install with my motor all torn apart at the moment. I'm not sure I want to wait until "at least the end of February" to do rod bolts.
What do you guys suggest? I could do ARP but then I worry about having bearing problems...
Or I could just swap them out with 01'-02' rod bolts.....
The car will probably not see more than 6600-6700 rpm in it's lifetime, what do you guys think I should do?
I just don't feel comfortable seeing as how it's a 98' with stock rod bolts and 60 miles on them.
Well I'm pretty sure you need to resize the rod end when you go with the arp bolts if not the bore could be out of round and cause a knock or cause you to spin a bearing. This is just what I've read but am starting to believe it's internet misinformation and it's being made into a problem much bigger than what it really is. I mean I see warnings all the time but see very few actually problems popping up....
That being said, the GENERAL recommendation when installing new rod bolts is to have the big ends resized. Does that mean that you have to....no. I would recommend measuring big end concentricity when installing any new rod bolt.
No. 1 rule of thumb when dealing with engines....measure, measure, measure, and measure.
i'm putting ARP's in mine when doing my h/c this winter and i'm not worried about it at all. ARP is very well know company and i think they make a great product i don't think they would put out a bad product. i have the "cracked rod" bolts. i think it's all hype like was said i've heard of people saying to go with the katech's instead but i've never acctually heard of any problems with the arp's.
If you can install a Katech bolt without resizing the rod than you should be able to do the same with the ARP. Heck, I wouldn't be surprised if the Katech bolts we made by ARP.
they are wider..that is why you are supposed to resize the rod ends with them, with the katechs you bolt them right in. I have also heard that the arp are heavier as well, that doesn't really make much of a difference but i have been told by many people to just spend the extra money on katechs. Mind you these are people that have installed both brands in numerous cars
So, doing a little bit of research.....the Katech bolts are H11 tool steel which has a higher tensile strength than ARP 8740 but is about the same as ARP2000.
Comparing the Hi-Perf and Katech > advantage Katech
Comparing the Pro Series and Katech > toss up
I don't know about the weight of each, so I can't comment.
Ive only heard of this being a problem on the 98 models. It didnt make a whole lot of sense to me. Mine is a 99 and I just had the ARP's installed about a month ago in preparation for the nitrous. No problems here. The work was done by Bryan Pavlock of Pavlock Performance, a sponsor thats has quite a reputation down in the Texas section.
I didn't resize my rods when I did my ARP rodbolts... Works great, beaten the **** outta the motor ever since for like 3000 miles. The instructions didn't say anything about resizing the rods. In fact, I dont know why you would need to? The rods used in an LS1 are a cracked rod unlike SBC rods and so forth which need to be resized every time you take em apart and put new rodbolts in em.
