F14 ptv clearance
F14 ptv clearance
Putting this cam in my buddies car this weekend, and I am going mill the heads tomorrow. Safe to mill .030 with gm mls? I assume it is, just wanted to see if anyone has run it. 232/234 .598/.598 112+2. Intake duration leads me to believe there shouldnt be any problems.
Thanks
Brandon
Thanks
Brandon
LS1 Tech Administrator
If the head has stock valve sizes, then you should be OK on P to V clearance. It will be tight, but that IVO is in a pretty safe area.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Thanks
Brandon
Thanks
Brandon
also have ported and milled .030.. 2.02/1.57 castings #853's WHAT SIZE PUSH RODS DO I NEED, dang, i know lots a racers have gone this route, i can't get a good answer.........I need help!!!! i guess the only way is with lenght checker huh? ......can't afford better heads so.....poor man's budget..lol
so, i have similar question, installing ms3 cam 237/242/606/609 lsa 113
Patrick the heads have 2.02 valves, but you dont lose anything worth mentioning over the stock 2.00.
Thanks
Brandon
I'm running an F14 on 5.3 heads milled about .005" (60cc) So that's equivilant to 5.3 heads milled .035". I'm also running 2.02" intakes. I used a MLS .054" gasket. All said and done I have .100" intake clearance and .180" exhaust clearance. My pushrods are 7.450". Of course my valve train geometry is more like a 241 head milled .005"
If I take the heads off I will re-install with .040" Cometics and go for more compression.
