Buying Salvage LQ4
Old 02-01-2008, 08:38 PM
racermike68's Avatar
Default Buying Salvage LQ4
Hey guys... I'm looking to jump into the LSX game and I've come across an LQ4 from a wrecked Yukon. This thing was hit pretty hard... hard enough to shear off the passenger side of the water pump, broke off the TB and the front of the manifold... even popped the freeze plug out of the head. So... do I take a chance on this, even if I can pick it up cheap???
Attached Thumbnails Buying Salvage LQ4-dscn1618.jpg   Buying Salvage LQ4-dscn1622.jpg
Old 02-01-2008, 09:05 PM
jkwalkercchs's Avatar
how cheap is cheap??
Old 02-01-2008, 09:06 PM
$350...
Old 02-01-2008, 11:09 PM
5.3LJimmy's Avatar
Make sure the block isn't cracked where the starter bolts on. When they are hit that hard it usually cracks there. And also check that the manifolds aren't pulled away from the heads, cuz that's a problem area too. The price is nice, but I would check it real close.
Old 02-01-2008, 11:19 PM
Thanks 5.3LJimmy, that's the kind of info I'm looking for! I'm going to look at it again tomorrow, I'll keep you posted
Old 02-02-2008, 12:17 AM
stevied916's Avatar
make sure you check everything. That's alot of stress on those parts and there are probably small cracks that you wouldnt see unless you looked close
Old 02-02-2008, 12:21 AM
Sharpe's Avatar
That's scary... but for $350.... If that's not much to you, then yeah, you might chance it. I mean, that's right on the edge for me. If it were an LS2 or L92 I wouldn't think twice!
Wil they let you do a compression/leakdown test on it?
Old 02-02-2008, 06:30 AM
ls1leadfoot's Avatar
i picked one up that was in a little bit better condition......that one looks pretty rough.....350.00 is a great deal.....but as they said.....make sure at a minimum the block isnt cracked.......sitting on it's side you are going to have some rust lines on the cylinder walls.....that means going straight to the machine shop for a hoan and new freeze plugs....
i have a bare ls1 block for sale for 350.00 has a fresh hot tank bath and new cam bearings....cylinder walls are straight and no problems
let me know
Quick Reply: Buying Salvage LQ4
