Bottom/Crank Pulley Runout?
Old 02-04-2008, 01:58 PM
lstvr's Avatar
Default Bottom/Crank Pulley Runout?
My bottom/crank pulley has some runout that is visible when its running, is this acceptable? Its a standard pulley with rubber ( or similar ) in its construction.
Old 02-04-2008, 03:37 PM
vettenuts's Avatar
They all seem to have some minor wobble, but if you have some miles on it and its moving a bit then it may be time to swap it out. They seem to go about 50K miles before they start going bad (just an observation based on posts I have seen).
