Possibly going different route with motor, need advice (Kinda long)
Okay, I've been posting on here for quite a while now about my H/C setup. I began flycutting and was needing to go in the neighborhood of .100+ on the cuts. Well ultimately I am wanting the car to run very, very low 10's or high 9's in the quarter and I'm pretty sure for me to get there the car is going to have to be sprayed 150+ shot of nitrous. Probably 200ish. I've read alot of posts about people having problems and it not being safe to spray that much on a piston that has been cut as deep as .100". To be honest, 150 shot is probably pushing it on the stock bottom end as well.
Now, I know that the stock crank is actually good to a pretty good number. 700RWHP I believe I remember seeing, so that shouldn't be a problem. However, I will need new pistons and rods. Also the rods will need to be recessed to be able to fit an MS4 and PRC 5.3 2.5's milled to 59cc. I'm not really sure what rods and pistons to even begin looking at though. I would need some help trying to determine what pistons and rods to go with.
I have the motor completely out of the car right now and I don't really want to have to pull it again in the near future to just do rods and pistons. I think I would rather just do it now but I want to know what you guys think.
Would it be better to just go forged pistons and rods now if so which ones? Or should I just cut the pistons and the stock bottom end will probably be okay with around 150 shot?
I need some insight, thanks guys!
Contacting a sponsor for specific advice is definitely a good idea though.
At that power level, although your stock shortblock MAY last, I would surely put forged pistons, aftermarket rods, ARP2000 rod bolts, and some nice head studs on it. Like you said you are mostly there and the additional money spent on beefing up the bottom end will be worth it for the peace of mind you will have.
