degree a torquer v2 cam
is it a good idea to degree this cam or just put it in straight up a buddy told me it makes a big difference if you degree it. its the .595 .598 232 234 cam.
I don't know enough to form an opinion myself. But here's a thread I found that kinda talks about it. I'm looking at the Torquer 2 myself. I'm waiting to see his results.
https://ls1tech.com/forums/showthrea...ight=2+torquer
Degreeing is done to make sure the cam is installed as intended cam designer/grinder. It is always a good idea to check because cams are sometimes not ground as specified. So if you want the most out of your Valve Events make sure you degree it.
I have texas speeds 233/239, and its supposed to make max power at about 6300, so i put it in dot to dot. I have my dyno sheet hanging infront of me, and its max power is 6,600, meaning i have to shift at 68 or 69 and have my limiter at 69 or 70. I dont remember the torquer v2 powerband specs, but mine ran above what it was supposed to, i probably should have degreed it +2 but i didnt know at the time
He wouldn't know that until he degrees it to fine out if it is ground true then he could decide if he wanted to advance it or retard it. It may be off in such that he has to retard it 2 degrees on the timing set to get it to install "straight up" according to the specs.
Lol, I feel retarded... I need to go read more on cams before I throw in my 2 cents. I didn't know the dots would be off if the advance/retard was ground into it.
Disregard my second post in this thread, lol.
On topic: I'd like to know how advancing it a few degrees would change the power under the curve. And how much you can advance it till it starts hurting performance.
Ex. If you install your 112+2 cam dot to dot if the cam is ground correct you would be installed with a 110 ICL. Which is what the cam is designed for. The degreeeing process simply verifies that it is in fact installed on the 110 ICL that it was designed for and that the cam was ground correctly. If you degreed the cam and it came out to be that the ICL wsas 108 then you would have to adjust your timing set 2 degrees to attain you cam's designed ICL.
How much you can advance it before hurting top end power too much depends on your cam and your set-up. They all vary.
I am not saying the dots would be off if the advance/retard was ground in. What I was getting at was that the cams are not always ground perfect and that you need to degree the cam to make sure that the way you install the cam takes full advantage of the valve events that the cam was designed for.
Ex. If you install your 112+2 cam dot to dot if the cam is ground correct you would be installed with a 110 ICL. Which is what the cam is designed for. The degreeeing process simply verifies that it is in fact installed on the 110 ICL that it was designed for and that the cam was ground correctly. If you degreed the cam and it came out to be that the ICL was 108 then you would have to adjust your timing set 2 degrees to attain you cam's designed ICL.
My new advice is to degree it for sure. Why not take the time to verify the cam is going to act how you want it to act.
I just installed my torquer without degreeing it. Its got 2 degrees advance ground in. It really really spins high, peaking after 6600, so i wonder if its actually ground with less than the 2* advance the cam card states. Great cam though, but it loves to spin high.
