Dart 225 heads...now what valves???
I am picking up a set of unassembled Dart 225's...I'm curious what valves some of you guys are using to dress your heads. I have everything else but havent desided on the valves. I have my cam (vinci 222/228 .551/.551) and crane 1.8 rockers so lift is not going to be crazy but I am planning for the LM Speed Maggie kit. Power output range is between 525-540 horse. Sooo yeah what are your opinions on the VALVES?
ahh sweet. I didnt realize the valves from Dart are so far up there. I knew they would do well for my setup but wanted to read what others thought. Thanks for the info. What were your numbers BTW??
As an FYI, you will most likely have to flycut the intake side for this to clear. I'm using the same combination you will be. I flat milled the heads .022 and used a Fel-Pro 1161L and 1161R head gasket (4.100 bore, .053 thick) and had .056" PTV clearance on the intake side and .101 PTV clearance on the exhaust side.
My pistons were .008 above the deck, so my SCR with the above combo is 11.31. The DCR, which I don't put much stock in, is 8.27.
What springs are you using?
Ahh more good info. Looks like I may have some flycutting in my future. I am lookin at maybe doing some forged rods and pistons. I'f I am gonna be flycutting I may as well. Thanks again man.
The valve spring seats on these heads require a .562 ID which is different from most other heads. Make sure you specify the correct spring seats for the springs you will be using.
For head gaskets, make sure you use one with the correct bore diameter. These heads have a 3.970 chamber width, so you will need a gasket with a minimum bore size of 4.00 inches. Dart recommended to me either the GM 6.0L MLS or Fel-Pro 1161 head gaskets.
I just realized I forgot to add the spring info for ya...They are Crane duals. I'll have to measure them out before hand. I still have some time before I finalize head gaskets and what not so I have time to deside. Alot of FI guys run the 6.0 MLS so thats the direction I am probably going.
Which Crane spring are you using?
If I remeber correctly they are 832's I dont have them handy to check. Do you have a link to go off of from Futral or the info from them? You haveno idea how much of a help you have been so far.....I'm surprized no one else chimed in.
Dart part # 2320051 or Futral Motorsports FMS-3988
Specs:
OD: 1.240
Spring ID: .650
Thickness: .060
As far as springs go, I would install the 144832's at 1.750 installed height. Here is the installed height I got using the Dart valves and the following components:
Crane 144661-16 retainers, Crane 99107-1 keepers, Futral MS FMS-3988 Locators: 1.775 Installed Height
Here's what the 832's will work out to be installed at 1.750:
So you will probably need approximately .025 in shims to get to 1.750 installed height. For shims, I used Isky Micro Shim Kit #6. Here's what it comes with:
Hmm I will have to measure the spacers I have and see what I come up with. I guess you had a lot of leg work before your install. You are saving much needed time.
1.045 - Coil bind height
.060 - minimum clearance required before coil bind
+_______
1.105 - Subtotal
1.750 Installed height
1.105 - subtotal from above
-_________
.645 maximum lift
.695 lift would be maximum lift at 1.8" installed height; however, I wouldn't use the 144832 spring for Comp XER lobes. If you want to stay with Crane springs, the 144833 is the spring I would recommend. The PSI 1511 is also a great spring if you don't mind a single beehive.
