G5X2
G5X2
Ok...I was wondering something..I am getting a new shortblock with diamond piston's -2cc releif's and using my T.E.A. S2 5.3 liter's on the motor...The head's are milled .030...would -2cc releif's be enough for the G5X2 in this motor? And what pushrod's should I use..7.350's? Thank's,
Carter
Carter
Re: G5X2
Are you assembling the motor yourself? I would check the p to v clearance on any new motor, especially with a cam the size of the g5x2. I don't think that you will run into any problems, but it's nice to have that piece of mind when you turn that key for the first time. Just my .02
Re: G5X2
Thank's alot guy's Yes i am assembling the motor myself...Just kind of aggrivating when checking PtoV and find you have NONE just wanted to check with ya'll and see if anyone knew before I found out on my own if i had clearance Thank's again,
Carter
Carter
