gm head bolt part #
Old 02-13-2008, 03:11 PM
124TURBO's Avatar
Default gm head bolt part #
Does anyone know what part # to use when installing l92 heads on a lq9 block? The ls1 bolts are way to long.
Old 02-13-2008, 06:36 PM
MM98's Avatar
Here ya go man:
Both these style of bolts are used on the 2nd design LQ9's & all L92's.
Long bolt- pat# 11519772 qty.20
Short bolt- part# 12558840 qty.10
The earlier LQ9's used three different bolt sizes in the heads, so if your block is threaded this way, you might want to go this route.. Not sure if you have to though.
Long bolt- part# 11588291 qty.16
Med bolt- part# 12560745 qty. 4
Short bolt- part# 12558840 qty. 10
Hope this helps you!
-Mike
Quick Reply: gm head bolt part #
