difference in ls1 and ls2 243 casting number heads
Old 02-19-2008, 10:57 PM
CaMaRo67RS355's Avatar
Question difference in ls1 and ls2 243 casting number heads
any difference in LS2 #243 heads and LS1 #243 heads?
Old 02-19-2008, 11:58 PM
jetlag's Avatar
Well it's not really LS1 243, they are LS6.
and I think they have different valves.....
Old 02-20-2008, 12:04 AM
i meant ls6 my bad guys typed it too fast.
any gains over the ls6 going with the ls2?
Old 02-20-2008, 12:08 AM
jetlag's Avatar
I'm not 100% sure, but I think they are pretty much the same except for the valves.
(Althought LS6 intake is better than LS2)
Old 02-20-2008, 11:40 AM
1Topgun's Avatar
My understanding is that the heads are basically the same...the difference is the type of valves installed. GENUINE GM LS6 heads have lightweight hollow-stem intake and sodium-filled exhaust valves. Replacement cost of the valves alone is about $650 for 16. The benefit of those valves is the ability to rev to 6600+ rpm, with the 90# LS6 springs without valve float. Those springs rob less HP than ~130# springs needed with standard weight valves to run at that rpm or higher.
Mike
Old 04-13-2008, 12:16 PM
99T/AMAN's Avatar
so does this mean that the ls2 heads are the same as the ls6 heads but with different valves?
Old 04-13-2008, 01:54 PM
1Topgun's Avatar
Yes, that's right...same head casting #, same combustion chamber cc, same intake and exhaust ports, same valve sizes (2.00 & 1.55)...just different valves. LS2 valves have the solid stems.
Mike
Quick Reply: difference in ls1 and ls2 243 casting number heads
