how do I check piston to valve clearance?
Old 07-16-2003, 10:40 AM
v8maro's Avatar
Default how do I check piston to valve clearance?
Anyone have a writeup for this?
I heard I could do clay (not so good) or the pushrod method, any tips are appreciated!
-Steve
Old 07-16-2003, 10:46 AM
Vents's Avatar
Default Re: how do I check piston to valve clearance?
use playdoh, clay ect...
just bolt down the heads w/2-5 bolts, with the clay installed, fix you're valve train and spin the motor. pull he head off, and check the clay w/ a mic. works like a charm ;D
Old 07-16-2003, 10:47 AM
Cal
Cal's Avatar
Make sure you tighten the head bolts down first, otherwise you won't get an accurate reading.
Old 07-16-2003, 10:48 AM
v8maro's Avatar
I was told the clay method wont give me a very accurate reading.
Old 07-16-2003, 12:31 PM
LS1Tech Sponsor
Slowhawk's Avatar
I use test springs and an adjustable pushrod.Just adjust pushrod to 0 play and rotate motor and check clearence with a dial indicator on the spring while pushing the spring/rocker down by hand.
Old 07-16-2003, 12:34 PM
Speed Demon's Avatar
Don't you need to use a solid lifter? I thought the hydraulic lifters would bleed down.
Old 07-16-2003, 12:43 PM
v8maro's Avatar
Where can I get this stuff and how much is it?
-Steve
Old 07-16-2003, 09:38 PM
LS1Tech Sponsor
Slowhawk's Avatar
With a test spring it will not bleed down
Old 07-17-2003, 12:38 AM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
Ditto! Why pull the heads to check clearance when all you have to do is pull a couple valve springs?
You need at least 1 adjustable pushrod and 1 checking spring, you can get a dial indicator at harbor freight or any good tool place.
Old 07-17-2003, 06:17 AM
Super Moderator
Reckless's Avatar
So if you have this stuff, what exactly is the procedure? I guess that is the hard part to understand.
Old 07-17-2003, 07:49 AM
v8maro's Avatar
I need all this by the 25th, where can I purchase it local? I have a few performance shops around here including scamchargers
-Steve
Old 07-17-2003, 09:11 AM
BergerMan's Avatar
V8Maro, what cam are you going to install??
Old 07-17-2003, 09:19 AM
v8maro's Avatar
TSP 232/228 .595/588 112LSA
with
Patriot performance S2 5.3L unmilled heads
-Steve
Old 07-17-2003, 02:23 PM
critter's Avatar
-Steve
It isn't local, but it is internet - Comp Cams sells the springs and dial indicator along with degree wheel and box for $185.57. It might be cheaper from a sponsor ...
