CC26918-Complete Junk After 2000 mile-Opinions Please
Asking the question for a buddy.......
Got some CC26918 (blue stripe) valve springs intalled at 1.78" with 224@ .050" .567" lift rockers that are completely dead (lowest tests at 70lb best at 120lb-average 110lb) after only 2k of running. What is your guys opinions of what has caused the springs to loose so much tension so quick? Have Comp Cams got a problem with this spring that it want live at well under the rated coil bind?
Has anyone had these springs go off so quick before because these things are complete junk and I need to know for him if it is common.
Re: CC26918-Complete Junk After 2000 mile-Opinions Please
did he live at 7000 rpm the entire time??? that's the only way i can see them going bad that quick. many people are running those springs with cams like the one you described and even bigger. i've never heard of them wearing out that quick
"Just when I thought I was out....they pull me back in..."
Arrrgghhh...just when I think I've decided on a valve spring, there's something like this that comes up
The LS1 has been out over 6 years now! ....and still we are waiting on a dependable valve spring.
Continuous valve float or misinstallation IMHO....
There are a few guys out there who missed their calling as NASCAR drivers. I think that kicks A$$, personally. I'm pretty sure NASCAR teams change springs after each 500 mile race....
Comp springs are junk.
They have had tonz of problems relating to quality control ...namely they have no quality control...
wasn't the blue stripe the bad batch??
i'm not sure here but didn't they have a bad batch about a year ago?
call them up and see what they say.
they did have a bad batch and that is why they started the blue stripe, to make sure you don't have the one's WITHOUT the blue stripe. His are from the "revised" batch.
I have almost 2 years and 20,000 miles on mine with no problems. Comp. may work something out for you on another set of springs or another type of springs. You will not get nothing but praise here on the 918s.
were they tested initially?
Cycled? Couldn't tell you how they were ran in.
They just seem to be real junk if they wouldn't live for 2000k!! Someone else must of had this problem surely......
I never had a problem with mine and i consider my cam pretty big. I have a few thousand miles on them and have bumped the limiter a few times, haven't had any trouble. good luck
I love my Rev dual valve springs...might want to check on their single coil springs for replacements. I'm running a .591 lift cam...also they're pretty quiet springs
Springs should not be compressed to coil bind, this is bad for them. My 918's have over 20,000 miles driven every day, and 70+ track runs, i dont run titanium retainers and i spin 6800 rpm on a regular basis. I have only lost 10 lbs on these springs since install and i have checked them twice. I love them personally!
tell em.. haha.. though I don't have huge miles on mine.. I beat em at the track so far...and not a skip yet.
Do you think that one compression to solid height is the difference between these spring working or not?
From other posts it would be safe to assume that the spring work fine in this application as long as it isn't abused...do you guys think that this spring was thrashed to get it to dump so quickly? Or do Comp Have a problem with this spring cause these things are DEAD!! Bent valves have resulted from it to make matters worse......
You seem to know what's going on...did you install these PERSONALLY so you know installed height was, in fact, correct??? I know I received a set of heads from a vendor (N-O-T my current set!) that had installed heights that were 0.1 short (partly because of the REV retainers that were used). Had I not checked this, it would have instantly resulted in coil bind and untold destruction!
If you have a blue stripe comp spring set it was shipped from the factory as a defective part.
Demand that they replace the spring set and have them pay for the labor for the spring change.
Next time avoid Comp and buy Lunati double REVs....
