Oil pressure question
Old 07-17-2003, 12:49 PM
theblur98ss's Avatar
Default Oil pressure question
Started my new 422 and here's my oil pressure. It's 80 on startup...starts at 60 cruising and then settles around 40 or so. Hot idle drops down around 20ish but will get higher if I rev. Is this normal or should I check the O ring. I used an ARE pump. I also checked my oil level and it's a hair above the add mark. I plan to add a 1/2 quart.
Old 07-17-2003, 05:07 PM
Krazy98Z28's Avatar
Default Re: Oil pressure question
At hot Idle u should be at 40psi
