NGK TR6 on a N/A engine and no N20...
Old 07-18-2003, 10:07 AM
DougsHawk's Avatar
Default NGK TR6 on a N/A engine and no N20...
I'm experiencing a little knock, thought I would try the TR6's since I already have the cooler stat and run 93 octane. Any thoughts on running these plugs on a stock internals, no N2O N/A LS1?
Would I gap them the recommended gap of .060 or go a bit smaller, say .050?
Old 07-18-2003, 10:29 AM
KGSloan's Avatar
Default Re: NGK TR6 on a N/A engine and no N20...
i'm not sure about this but it was recomended to me by a shop to run the tr6's on my motor (stock except the cam) and to gap them at .040. i don't know really why, but it was suggested to me once
Old 07-18-2003, 10:35 AM
VTtransam's Avatar
I run them in my car. Gap set at .050, this is what thunder racing told me to do. No problems with them so far. I'm N/A as well
Matt
Old 07-18-2003, 10:39 AM
D(irecto)r Pepper
Raughammer's Avatar
I would highly recommed you try the TR6's.
Most of the "old timers" have been doing it for years to combat knock... especially in the summer months.
Good luck.
Old 07-18-2003, 10:53 AM
DougsHawk's Avatar
These are great replies, thanks!
Only thing I see as a potential problem is gapping them to .050. I know I have read somewhere that you shouldnt change the preset gap more than +/- .010 (The TR6's come pre gapped to .035)
Am I wrong in that belief?
Old 07-18-2003, 11:49 AM
Restricted User
CAT3's Avatar
Doug, that is a rule of thumb, not a law. But you will be ok gapping to .050.
Some say you lose NA power with 6's, but if not gapped right you will with any plug. I run them, yeah N2O also, but normal driving is on the 6's and no problems, i even run a tighter gap .038".
Have fun, Charlie.
Old 07-18-2003, 11:59 AM
STF veteran / 10 second club
x phantom x's Avatar
I've run TR-6's for around a year now, gapped at .38" also. No problems at all, car runs excellent.
Old 07-18-2003, 01:36 PM
Fulton 1's Avatar
I've been running TR6's gapped at 0.044" for years now. As John pointed out, I did it initially to combat KR. Worked really well too.
2000 SS #3240,BR,M6 - Hotcam,Grottys,Ram 910,Strange 12-bolt w/4.10's,Prokit springs,and G2 suspension goodies
Old 07-18-2003, 01:43 PM
NataSS Inc's Avatar
Just stay away from the Bosch platinum +4's. I just put mine in and had one hot day last week, and the car was knocking all over the place.
Old 07-18-2003, 03:06 PM
Pat-Man's Avatar
I hear you NataSS about the Platinum 4s...for some odd reason I decided to switch from my TR-55s and go with the Bosches....stupid stupid me! My car ran pretty good when I put them in, but once this Texas heat rolled in, my car has been running like poo! I went ahead and ordered some NGK Iridiums yesterday...my car should thank me...I hope. I heard a lot of good things about these plugs except that they are one of the expensive kinds. I hope they work all right. - Pat
Old 07-18-2003, 03:17 PM
Vents's Avatar
NGK'S are some of the best plugs i've run. take these other guys advise about the bosch's they are a tad too hot for our motors, especially if you've upped the cr. i can get away w/ 28* total w/ the Ngk's and 11.2:1, in my iron motor.
Old 07-18-2003, 03:20 PM
Patman's Avatar
I had the TR6s in my 98, at .044, when I ran my 12.68 at 110.6. According to Autotap I got no spark retard at all, even in fourth gear at WOT, and I even had a ported MAF and the HPP3 tuning.
So these plugs do help keep detonation away.
They don't last long though, I only got 13k out of them before they fouled up good.
Old 07-18-2003, 05:27 PM
Restricted User
CAT3's Avatar
Pat-Man...the NGK 'I's are cheaper than the Denso Iridiums. What number plug, I am trying to find out what the equivalent to the TR6 is in Iridium and then one colder for a DP-200shot.
Old 07-18-2003, 06:52 PM
Fulton 1's Avatar
Hey, who is this new "Pat-Man"?
And he has an LS1 too...
Old 07-18-2003, 07:14 PM
Patman's Avatar
Don't worry, I'll have another one someday, next one will be a C5 though!
Old 07-24-2003, 04:45 PM
Pat-Man's Avatar
Hello...I am the new Pat-Man. I'm jumpcable over at LS1.com. I actually just got my NGK Iridiums today and I am waiting to install them once my headers come in for my cam swap. See you all on the boards. - Pat
Old 07-24-2003, 04:56 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I always gap TR6's at .050 for NA applications. As long as you stay within .010 of the stock gap reccomended for a car it's fine.
Old 07-24-2003, 06:33 PM
SStolen's Avatar
13k! Ummm... I've had mine gapped at .38 for about 22k or so now. The car is running fine, no knocking at all. Am I losing power? I'm getting ready to do the mods listed in my sig below in about three weeks. Should I stay with the TR-6's gapped at .050? Someone recommended TR-55's at .050.
BTW: Is there any ill effects to leaving a plug in too long even if it's not knocking or misifiring? i.e. harder to get back out. I hope I don't break one off in there when I go to remove them. Thanks.
Old 07-24-2003, 06:52 PM
LS1Tech Co-Founder
I'd only go .038 for a mild nitrous application. Car might idle a bit better and have hotter spark with .048 and burn the fuel better.
With my blown application my plugs are gapped at .035.
