double check DCR/SCR
Old 03-01-2008, 12:46 AM
Nimitz87's Avatar
Default double check DCR/SCR
doing the calculations for DCR and SCR I came up with this.
heads are dart 205's 62cc chambers. milled to 60's.
cam is texas speed torquer 2.
advertised duration is 281/283 112 LSA w/ + 2 ground in 110 ICL.
for whatever reason when doing the calculations it says
overlap :58? that can't be right...
right now it says SCR 11.20:1 DCR = 8.50:1
is this right?
Chad
Old 03-01-2008, 01:48 AM
00cls1camaross's Avatar
you must be drunk, advertised specs are 232/234, .595"/.598"
[(234+232)/4 -(112)]/2=9*
Old 03-01-2008, 01:55 AM
Nimitz87's Avatar
[(234+232)/4 -(112)]=9*
thats @ .50 thanks...
calculator doesn't use .50
Chad
Old 03-01-2008, 12:55 PM
1999vetteroo's Avatar
is this right?
Chad
That overlap u came up with is advertised, not @ .050
I came up with 11.02scr and 8.36dcr base on the info you gave. Calculations vary so I think your in the ballpark!
Old 03-01-2008, 11:01 PM
Nimitz87's Avatar
ok cool appreciate that
Chad
