Are aftermarket underdrive pulleys known for throwing belts off easy?
Old 03-01-2008, 12:40 PM
CaMaRo67RS355's Avatar
Question Are aftermarket underdrive pulleys known for throwing belts off easy?
i have a ASP underdrive pulley with correct belt sizes it through the belt haaf way off about 5-8 times the past 6 months when i had the stock pulley on it never did that. well the other day i was going down the road and got on it and it started coming off so i popped the hood and checked and found it was ripped from riding on the lip of one of the pulleys.
im using the gatorback belt.
i also have a aftermarket thunder racing tensioner would this be the cause?
let me know what you think to prevent it...
Old 03-01-2008, 02:08 PM
ABQ99TA's Avatar
I have never had a problem with mine. You might want to check the alignment of your pulleys you may have not got the pulley on all the way.
Old 03-01-2008, 02:31 PM
Wilkenstein's Avatar
I had that problem and went with a katech tensioner. No problems yet!
Old 03-01-2008, 04:32 PM
what belts are you using?
Old 03-01-2008, 06:08 PM
DONAIMIAN's Avatar
My vote is for an out of alignment pulley. I have one of the early ASP pulleys on the stock tensioner and never had a problem with throwing belts.
Old 03-01-2008, 06:54 PM
Ryan02SS's Avatar
I agree. The belt should not throw unless a pulley is out of alignment. I would bet the ASP crank pulley is not fully seated. ASP here 4 yrs no thrown belts. Stock tensioner.
Old 03-01-2008, 07:21 PM
Viper's Avatar
Mine was fine until I went road racing. Granted, sustained high RPM is not what you will see on the street or a drag strip. Anyway I caught it (the belt) before it walked off, it was on 2 ribs. March pulley.
