LS1 to LQ4 swap. NEED HELP!!!!!
Old 03-03-2008, 02:59 AM
Boosted408's Avatar
Default LS1 to LQ4 swap. NEED HELP!!!!!
Anyone in here make the same swap? I spun a rod bearing in my LS1 and purchased an LQ4 to replace it. What is re-useable and what will I need to buy? Any info would be greatly appreciated.
Old 03-03-2008, 08:28 AM
black_z's Avatar
The engine itself will swap right in. You will have to swap your LS1 accessories on the LQ4 (crank pulley, alt, etc) The alternator will require you to drill and tap for the 3rd mounting bolt.
Old 03-04-2008, 06:28 PM
Boosted408's Avatar
Default Thanks
Thanks for the info. Anyone else got anything for me?
Old 03-04-2008, 06:30 PM
ls1leadfoot's Avatar
all the bearings, bolts, studs, and you crank and knock sensor as well
