Low oil pressure? water on oil cap also.
I had some ticking on my motor that comes and goes, usually you can only hear it when its cold. It goes away after 15 minutes of driving maybe. I ran regular 10w-30 on the car before and thought that would have fixed it, but it didnt. So I went out and got some seafoam and changed my oil to 5w30 mobile1 synthetic and that made no difference. My autometer oil pressure gauge reads about 17 i think at 800 rpm when its warmed up. When I rev it to 2k it would go up to 25psi. But I have never seen it go higher than roughly 26psi no matter what RPM i'm at. Could it be my oil pump is going out? Maybe the o ring for the pickup is broken?
Also I just checked my oil cap and when I took it out, there were drips of water(maybe about 3 drips) and some plaque like resdue. I'm thinking I could have a bgh but the oil isnt milky, and I dont overheat.
Specs:
stock 99 ls1
6 quarts of mobile1
mobile1 oil filter
car runs at a steady 195(using a temp sensor on the passenger side head)
Thanks
Specs:
stock 99 ls1
6 quarts of mobile1
mobile1 oil filter
Thanks
