6.2L with MS3 dcr,scr?
Old 03-04-2008, 07:47 PM
sroka's Avatar
Default 6.2L with MS3 dcr,scr?
Not sure if my math is right or if i even did it right, but im coming up with 11.97-1 SCR
8.72-1 DCR
Spec are
6.2L shortblock stock pistons -3cc
3.622 stroke
4.065 bore
60cc heads (243 milled .030)
.041 head gaskets (fel pro 1041)
MS3 on a 113
Thanks for the help
Old 03-04-2008, 08:19 PM
sroka's Avatar
Damn it i just re-did the math and came up with DCR of 9.33-1
wonder if this is right and if so is anyone running that high on pumpgas?
Old 03-04-2008, 08:46 PM
JimMueller's Avatar
What's the connecting rod length for the 6.2L motor and the advertised intake closing angle of the MS3?
Old 03-05-2008, 06:22 AM
sroka's Avatar
rod is 6.098"
don't know the advertised intake closing angle.
Old 03-05-2008, 07:44 PM
sroka's Avatar
Anyone?
Old 03-05-2008, 09:44 PM
iamsickofitall's Avatar
i've got 11.97 SCR and 8.64 DCR using a Comp XE-R 236 intake lobe for reference. DCR using a 238 lobe is 8.55.
i also used -.007 on the deck height and assumed there was no advance ground into the cam.
if you are getting 9.33 in your DCR calculations, you are probably treating the dish on your pistons as a dome instead. the ci's for the pistons should be a positive number, not a negative.
