How my tune and is this right??
Old 03-04-2008, 10:49 PM
fattony's Avatar
Default How my tune and is this right??
I reciently got a mail order tune for my ls1 here are the mods
2000 LS1/ M6
TSP T2 Cam
1 3/4 long tube headers
2 1/2" custom x pipe
2 1/2" exit exhaust
Intake
Dyno results 271hp & 258tq
my question is I am only getting aroung 170miles to a 17gal tank or anywhere from 9-12mpg is there something wrong????? I attached my dyno and how is the air fuel ratio it it good or bad????
Thanks
Tony
Old 03-05-2008, 12:36 AM
stevied916's Avatar
wow, it's wayyy to lean. It should be near that red-dashed line
Old 03-05-2008, 01:29 AM
Gun5's Avatar
your good then your going lean later in the higher rpms
Old 03-05-2008, 07:24 AM
fattony's Avatar
....??? so what should my afr be?
Old 03-05-2008, 08:00 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Its ok to have a Lean tune in the lower rpm's and part throttle but when you got to WOT its gotta be in the 12.8 range for NA car and lower for FI applications.
I had a car that ran 14.8 to 1 from idle to 2.5k, as soon as WOT occured it instantly dropped to the desired range and it was safe.
Your running 14 to 1 on the WOT and its slowly going down.
Do you know if that dyno has an issue with their A/F meter??
Old 03-05-2008, 08:18 AM
fattony's Avatar
no this was a dyno day and one guy said his tune from another shop show the same thing so I m asuming that it was on point. also if mine is 14 -1 at idle and goes down at WOT is that good or bad, sorry if I sound confused but I just trying to understand the AFR
Old 03-05-2008, 08:38 AM
ChrisH821's Avatar
2000 LS1/ M6
TSP T2 Cam
2 1/2" exit exhaust
Intake
Thanks
Tony
Is it just me? I am seeing 371hp 356tq.. It is a bit lean, shouldnt the red dotted line be at 13:1? not 11.8:1 or whatever its at in the pic? It looks like you are starting out near 14:1, then at higher RPMs it looks like it lowers to 13:1 give or take.. at least it doesnt stay at 14 throughout the range
Old 03-05-2008, 08:58 AM
fattony's Avatar
so 13:1 is optimal
Old 03-05-2008, 09:11 AM
ChrisH821's Avatar
yep...
as for your MPG, are you a "spirited" driver? or is that highway milage?
Old 03-05-2008, 11:45 AM
fattony's Avatar
you know what they say "redline a day, keeps the carbon away" but I am consertive driver and most of my driving is highway driving.
Thanks
Tony
Old 03-05-2008, 01:30 PM
GT Griller's Avatar
*EDIT* i didnt see that u had a mail order tune done
Old 03-05-2008, 01:35 PM
Mike @ New Era's Avatar
Where are you located ? You should get the car custom tuned , a mail order tune should be used to get you to the dyno and have it custom tuned .
Old 03-05-2008, 02:40 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
It's not horrible, if you're not getting knock. From what I can see, it's like 13.8:1 at low rpms and begins to drop as the rpms rise. Although 170miles a tank seems low, it's not crazy. I typically see 230-250 depending on how I drive. If you are throttle happy, I can believe 170miles per tank.
Old 03-05-2008, 06:36 PM
fattony's Avatar
pcm for less did my mail order tune
I am located in northern VA and I am ordering Heads and and Intake manifold (on there way) so tune should be comming up shortly
considering this is my first V8 also it is in an RX7 so I get throttle happy frequently I need to control myself.
Old 03-05-2008, 06:44 PM
MrElectric03's Avatar
Yea that wll do it...if you kept the throttle normal you should actually get pretty good milege being as your car weighs less than an Fbody.
Old 03-05-2008, 11:34 PM
fattony's Avatar
does any one here know who I can goto for a tune in the DC metro area ie VA, DC, MD also will I need to buy a tuner software or do places have software???
Old 03-07-2008, 01:25 PM
tattooed4lyfe's Avatar
call Jason @ F-Body Central they are around Baltimore 410-242-0404, this is what they do, so call `em
