final say: ms4 or trex
Old 03-05-2008, 09:07 PM
SSstud's Avatar
Default final say: ms4 or trex
alright everyone has their own opinion on which cam they prefer for their
f body..ive been looking at a lot of threads and it seems that both these cams get a lot of compliments for cam only applications...disregard the idea of custom cams and think only about the ms4 or trex...
what cam do you like best and why?
Old 03-05-2008, 09:36 PM
NC98Z's Avatar
Pure race car T-rex. Street/Test and Tune on Sunday for braggin rights MS4. Open headers is one thing and a street driven car is something else. T-rex is too extreme for the steet for me.
Old 03-05-2008, 09:39 PM
santiago's Avatar
its obvious you want a big cam,that being said get the biggest one!
sixpack_2_go's Avatar
yes, i would like to hear what people have to say about this too. also list hp and torque you got from you cam and e/t's if you have them.
Old 03-05-2008, 09:46 PM
dshag's Avatar
i would say use the cam best for your setup, either of those cams will be good, it really depends what your application...im still up in the air to which cam ill choose when i do the mod
Old 03-05-2008, 09:48 PM
brad8266's Avatar
Neither with stock heads and/or un flycut pistons.
Old 03-05-2008, 09:56 PM
Top Fuel's Avatar
what size stall? what size gear? whats the rest of the combo? neither of those cams will work for you with the mods you have listed in your sig.
Old 03-05-2008, 09:59 PM
THEE PEWTER Z™'s Avatar
pistons.
Trex works fine under stock heads... I KNOW THAT FOR SURE...No notching or flycutting..
Old 03-05-2008, 10:00 PM
brad8266's Avatar
Uh huh, did you measure your piston to valve clearance after you installed that cam?
Old 03-05-2008, 10:01 PM
2000Hawk's Avatar
With either cam your going to need gears, if you don't have them already, 4.10s will make your car fly off the line with either of those cams. On the stock 3.42s my MS3 isn't that impressive at a low rpm, but when it gets up there it really starts to move out. What are you looking for out of the car exactly? Track, light to light occasions, etc.? Like you said both cams get great compliments, but what mods do those that praise them have. Because if you expect to be quick off the line with your factory gears, and no nitrous, then you might want another choice. If you just want a cam to say my cam is "Big", then either one will work for you.
-Joel
Old 03-05-2008, 10:03 PM
what about my setup? ms4?
Old 03-05-2008, 10:05 PM
rocksws6's Avatar
I would take the rex out of those 2.
Old 03-05-2008, 10:07 PM
2000Hawk's Avatar
You have 4.10 gears so your car is going to move, compared to mine. I don't have any experience with the MS4, since i am currently running the MS3. I was contemplating on going with nitrous, but i have no opted out of it. Now i wish i would have gone and sold my MS3 for the MS4 prior to the install. Either way you can't go wrong with Thunder Racing or Texas-Speed cams, you just have to find the right one for what your looking for. I suggest if your not stuck on one cam, you call one of these shops and see what kind of specs they throw at you. You just might get better performance off one they custom grind for you, rather than one off the shelf.
-Joel
Old 03-05-2008, 10:19 PM
SSstud's Avatar
generally you do not need to flycut pistons...both cams fit stock heads and pvc is not a big problem...although, it is very close. lets just say over revving too much would set you back more than youd like...
as of right now, im running stock 3.23 gears, and a stock stall...
BUT...when i do decide to put the cam in, i will have a pt4400 stall or 3.73 gears installed, or maybe both...so on that note, what do you think?
Old 03-05-2008, 10:23 PM
brad8266's Avatar
So you think very close PTVC is not a problem? Who told you that?
https://ls1tech.com/forums/generation-iii-internal-engine/875410-trex-cam-problem-thunder-said-fine.html
Old 03-05-2008, 10:32 PM
ssfast99's Avatar
stop with the ptvc crap. i have milled my stock heads and ran the t-rex to 7200rpm on a normal basis. i now have patriot 243 and have no problem. amber and joe were running a cam bigger than the t-rex with 243s and had no problem. the trick is staying with normal sized valves. anyways, i love my t-rex and would never change unless i went even bigger. whatever you get the tuner has his work cut out for them to do it right. i spent 8 hours with my tuner on a load dyno fixing what a shop in vegas screwed up. my buddy had afr225 with a m4 and had some really weird motor probs, probably has nothing to do with the cam but i like the t-rex.
Old 03-05-2008, 10:36 PM
CaMaRo67RS355's Avatar
ms4 i didnt like the powerband being so high with the trex really doesnt awke up to like 3500 or more RPM's
Old 03-05-2008, 10:38 PM
Top Fuel's Avatar
go for it, it'll roll. what do you have past the headers? both of these cams love free flowing exhaust. Its generally best to have it dumped at the axle, or even better mufflers off the collectors
Old 03-05-2008, 10:41 PM
brad8266's Avatar
Originally Posted by ssfast99
stop with the ptvc crap. i have milled my stock heads and ran the t-rex to 7200rpm on a normal basis. i now have patriot 243 and have no problem. amber and joe were running a cam bigger than the t-rex with 243s and had no problem. the trick is staying with normal sized valves. .
Yeah ptvc is now crap because you say so, lol. Do amber and joe run a stock piston or an aftermarket one with valve reliefs in it?
Old 03-05-2008, 10:43 PM
Top Fuel's Avatar
IMO, MS4
