which cam with PRC stg 2.5 5.3L heads
I am looking at Texas Speed's head and cam package for my stock bottom end 99 SS. Ive heard nothing but good things about these 5.3L heads. I was wondering which cam you guys would recommend for this application. I want to have a noticable idle, so no worries about keeping it sounding stock. Is there a lift limit with these heads because of the combustion chamber size? Also, with these heads, is there anything that needs to be relocated or are they a exact bolt on replacement. Thanks.
I have that setup and it works good, ls6 intake, pacesetter headers, through full exhaust, loose stall, 3.73 gears I put down 410/370. At the track it went 10.84 on a 150 shot, don't have any NA track times yet but going with a bigger stall and 4.10's this year. Will post times when our 6 feet of snow melts!
Check out the TSP 233/239 cam. I run that cam and I have these heads. I have yet to get it dynoed with the heads on but I put down 406/374 with the following:
pacesetter headers & ORY & borla catback
SLP LID
233/239 Cam on 112LSA with 918 springs
Those numbers are through a 9" mind you, 10bolt numbers would see a 10-15hp increase on the dyno.
I expect a drastic increase in dyno numbers when I finally dyno again, since I have also added a ported TB, underdrive pulley, the heads, and a few of the free mods.
SLP LID
